STM32 MCUs Products
Capture egdedirection on input capture with dma
Hello,i am using the STM32F410CBUx and want to detect rising and falling edges with the Timer 5.I get these values with the help of the DMA because the signal edges are close together and i need accurate meassurments. The edges occure all in a short ...
PDieh.1 by Associate III
  • 4210 Views
  • 8 replies
  • 1 kudos
How to use an external signal to trigger ADC on H755ZI?
 Hello,As the title says, I need to use the ADC's external trigger designator pin to trigger the transition. I have done the necessary steps on Cubemx but my code still cannot work.Looking forward to hearing from the forum.Thanks,HAILV /* USER CODE E...
Ruồi by Associate III
  • 1363 Views
  • 1 replies
  • 1 kudos
Resolved! Error in UM2861
at page 26 :"The X3 crystal has the following characteristics: 32.768 kHz"it should be X2 instead of X3
nicolas by Senior II
  • 1357 Views
  • 1 kudos
Resolved! STM32G030K6T6 with PWM
Hi,I'm trying to configure the PWm with STM32G030K6T6. But pwm is not generate.below I given my code and i don't know where i made a mistake if any one know help me.RCC->IOPENR |= (RCC_IOPENR_GPIOAEN); // I/O port A clock enable GPIOA->MODER &= ~(...
Resolved! When downloading FW on the stm32L476ZGT EVAL,
When downloading FW on the stm32L476ZGT EVAL by using CubeIDE1.10.1ver, I faced with Error: Failed to download Segment[0], Error: Failed to download the File...,How can I solve these problems? Even I didn't write any code in there. Following is my Co...
Jlee.16 by Associate
  • 5799 Views
  • 4 replies
