STM32F429 to STM32H7A3 migration
KAgga.1
Hello There,
I'm looking to migrate from STM32F429ZIT6 to STM32H7A3ZIT6 for a TFT application.
I have checked H7 will provide better performance on this.
There is one more thing that comes to my mind that H7A3 has better specs than F429. Then why F429 price is still higher than H7A3.
Keshav Aggarwal
Pricing is multi factor issue, currently it is weighted heavily on availability and demand​. More generally it will relate to die yield per wafer, costs per wafer and time on tester.
You're going to have to own the porting process. Would suggest you start with a simple donor project, get all the clocking, pins and peripherals up, and then merge in blocks of your existing code adjusting and refactoring as you go.​
