STM32 MCUs Products
I am working on STM32G030 series microcontrollers & I am using external crystal as clock source (HSE). But as per AN2867 Application note(page13) gain margin ratio should be greater than 5, But I am not able to get it above 2.9. What should I do?
STM32G030C8T6 has maximum critical crystal transconductance (gm) is 1.5 mA/V.Crystal specifications that are mentioned in application note(page14) gmcrit = 0.23 mA/V with this gain margin > 5. But I checked many crystals datasheet but I am not able t...
SMali.4 by Associate II
  • 2431 Views
  • 3 replies
Resolved! STM32F407 Timer does not work
Hi I am trying to initialize TIM2 to get a PWM outpt from PA15 of my STM32F407 development board. Here is my TIM init function:void TIMConfig (void) { /*************>>>>>>> STEPS FOLLOWED <<<<<<<<************ 1. Enable the TIM2 clock 2. Set clock ...
kyouma001 by Associate II
  • 2258 Views
  • 3 replies
STM32H7A3 STM32H7A3ZIT6Q DMA Not starting
The code works fine on STM32G474 and I can get 1Msampe/second. I redid the same project on STM32H7A3ZIT6Q with the changes indicatedhttps://community.st.com/s/article/FAQ-DMA-is-not-working-on-STM32H7-devicesI went to the option having a dma section....
Marius CO by Associate III
  • 1545 Views
  • 1 replies
