STM32 MCUs Products
STM32H5 FLASH_ECCDETR address decoding
In the FLASH_ECCDETR register, the ADDR_ECC field description contains:"The address in ADDR_ECC is relative to the flash memory area where the error occurred(user flash memory, system flash memory, data area, read-only/OTP area)."But I'm having troub...
PieterG by Associate III
  • 1906 Views
  • 1 replies
STM32U585AII6 FMC cannot read and write PSRAM
Hello, I have a issue to control IS66WVE4M16EBLL-70BLI with STM32U585AII6. Although IS66WVE4M16EBLL-70BLI is 8MB, I can read and write only 8KB. IS66WVE4M16EBLL-70BLI has 22 address lines and 16 data lines.(4M * 2 = 8MB)     The problem is    if i ...
kongking_4-1718872404276.png kongking_6-1718872451878.png kongking_7-1718872567594.png kongking_8-1718872599895.png
kongking by Associate
  • 1144 Views
  • 0 replies
Resolved! Reading I2c with sub-address
Hello All.Reading a register value from an I2C device assumes:  Writing the device address-> Writing the register address without STOP-> Reading the value . I am trying to figure out if I can do it using only available HAL functions but I don't see h...
baranovus by Associate III
  • 2558 Views
  • 2 kudos
Error in AN2834 rev 9
Hello ST people, I spotted an error in AN2834 rev 9, figure 8. Please refer to the image attached.A negative offset error should be depicted in figure 8, but it is a positive offset error, just like in figure 7. To be a negative offset error, the act...
ke1wa by Associate
  • 1896 Views
Resolved! How to reset counter value ?
Hello everyone, i would like to know the HAL function that allows to reset the value of a simple counter. I don't find the HAL function to reset my counter to 0 before a next counting. So all i want to do is to count, read my counter value and reput ...
LHerm.1 by Associate III
  • 15612 Views
  • 6 replies
  • 2 kudos
Initialize the bootloader on STM32L432KC
I am a new embedded software engineer using STM32L432KC for my company's projects.I have been tasked to install a bootloader into this MCU. I am not sure how to proceed. I do understand that the BOOT0 pin which is grounded has to be set HIGH and BOOT...
Abijith by Associate II
  • 2545 Views
  • 5 replies
Resolved! How to write multiple file in sd card sdio using fatfs
Hi, 1.I want to save multiple files but only 50 or 55 files savings.and how to save files next to next file.I want to fo fill data files up to to 32 GB.  2. how to reuse same memory for multi file creationint main(void){ /* USER CODE BEGIN 1 */  /* U...
pankaj4 by Associate II
  • 2543 Views
  • 3 replies
  • 3 kudos
Flash memory data access
Hi.I want to save and load data to flash memory. (STM32F373RC)And initialization code was generated through cubemx.All functions including SPI, I2C, and ADC were successfully tested.However, saving and loading data into flash memory failed.All functi...
YS4 by Associate
  • 2222 Views
  • 1 replies
  • 1 kudos
Resolved! MCU can't be flashed anymore
Hi everyone,First I am sorry for the uneducated rest of this text and badly written code.I am currently playing around with a stm32f4 chip. I am using Platform IO CMSIS and a cheap stlink v2 to program the chip. I was trying to get PWM working when t...
Smar by Associate II
  • 2788 Views
  • 3 replies
  • 2 kudos
