STM32 MCUs Products
Resolved! Writing Key in OP Byte
Hello Team,I want to store encryption Key - 4 byte into Option Byte OR any other memory Except in-built Flash Memory.Is it possible to write in Option Memory ? If not what could be the other option ?
bsuthar by Senior
  • 1144 Views
  • 12 replies
  • 3 kudos
Unable to download library from ST official website
I tried to download library from https://www.st.com.cn/zh/embedded-software/stsw-stm32054.html several times but failed.When I clicked download v3.5.0, nothing happened. By the way, we network is fine. Is it forbiden to download this version?
ca11ac by Associate
  • 401 Views
  • 1 replies
  • 1 kudos
Resolved! NSSP mode - SPI
This is a question related to SPI communication.What is NSSP mode? What does it do?Also is there any documentation that explains all parameters in detail other than this
Resolved! Option Bytes changes does not work
HIUsing stm32f303veh6.Changed the option bytes with the CubeProgrammer. 2.20.0 to override the BOOT0 signal. ( its floating )nBOOT1 - > uncheckedBOOT_SEL -> unchecked I see that the address on start is 0x1FFFF.. and my FW on flash does not run. For d...
Rado1 by Associate
  • 11938 Views
  • 3 replies
  • 1 kudos
