STM32 MCUs Products
Tag connector on STM32H735G-DK.
HiI'm designing a PCB using the STM32H735 based on the eval kit STM32H735G-DK.On STM32H735G-DK there is both STlink connector and a TAG Connecter, but they are not wired the same way.I have the STlink working but was wondering what type of programmer...
Kvang by Associate III
  • 733 Views
  • 0 replies
Resolved! SAI1 DMA Callback Issue
Hello everyone,I'm currently working on a project using the STM32H723VE microcontroller and have encountered a problem with the SAI1 peripheral. Previously, I developed my code on the STM32H723ZG Nucleo and everything worked perfectly, including the ...
Custom bootloader and debugger issues
Hello,I am using an STM32WB with a custom bootloader, which is currently simple and only knows how to jump to a specific address to start the application. I upload firmware using debuggers (STLink V3 and JLink). When I upload the bootloader and the a...
JR2963 by Senior II
  • 2948 Views
  • 5 replies
STM32F373 Sigma Delta ADC: Filter Specs & FFT plots ?
Heyho,for a new project I need an MCU with 2 channels of 16bit / 50kHz ADC.It looks like the F373's sigma delta ADC (SDADC) might be good enough (it will be calibrated for accuracy anyway).But I haven't found any info about the SDADC's digital low pa...
LCE by Principal II
  • 1876 Views
  • 1 kudos
STM32H730 with OctalSPI ISSI IS66WVO8M8 PSRAM
Hello community,I'm looking for some direction on how to setup the OSPI bus to communitcate with an external PSRAM part from ISSI - IS66WVO8M8 (datasheet attached). I've read through application notes and a handful of example projects but am having a...
taylors by Associate II
  • 3518 Views
