STM32 MCUs Products
Resolved! Graph
Hi, any provision to plot array data in real-time during debug using F439 Nucleo?Please guide
GauravK by Senior
  • 892 Views
  • 1 replies
Resolved! STM32U575ZITxQ Port G GPIO Issue
I have just started evaluating the STM32U575ZIT6QU for a project that my company is working on.While attempting to evaluate the I2C pins for I2C1 on pings PG13 & PG14, I noticed that the pins would not work correctly and would stay low, even with int...
Resolved! RTC Drift
Hi,I have a custom board by STM32H743 and have some problems by RTC. I've used LSE with a 32.768 KHz external crystal. I have 2 or 3 seconds more in each minute. There is no reset within 3 minute and I see about 15 second more.I've used 6.8 pF for CL...
MHaji.1 by Senior
  • 1421 Views
  • 1 replies
Resolved! Problem with selecting HSE as system clock
Hi Every one.When i am trying to write CS bit of RCC_CFGR register of STM32G491RE MCU to select HSE as a system clock (i.e 10) it changes to 11 (01 is default so i guess i am not able to clear these bits before assigning new value). Can anyone tell m...
srbhktyr by Associate II
  • 1444 Views
  • 2 kudos
Resolved! systick handler keep pending on stm32h7 board.
I made a project with stm32h7 board, and use pemicro multlink to debug it under keil. I found it keep in systick handler pending but no active.I checked systick module register as:the counter is changed.and then I checked SCB releate registers asand ...
shengyang_0-1725578415036.png shengyang_1-1725578563853.png shengyang_2-1725578660534.png shengyang_3-1725578726103.png
