STM32 MCUs Products
Resolved! STM32H745 maximum sample rate
Hi,I'm looking for baseband processor for my IQ receiver. I would need dual 12-bit ADC with 5.12MSPS rate. I hope to get data from two ADC to DMA syncronously.I have been looking for STM32H745 for this task. Based on the datasheet, maximum sample rat...
mosamasa by Associate II
  • 1209 Views
  • 1 replies
Resolved! Ensure a pin is low while in bootloader
Hi and thanks in advance !My application uses a STM32G0B0 to control an LED driver through PWM among other things (pin (26)-PB14).The device can receive commands and I have added an option to jump to bootloader through a special command to perform fi...
4lch by Associate II
  • 3437 Views
  • 8 replies
  • 7 kudos
Resolved! STM32U599 DAC doesn't work in DMA mode.
I tried everything to send a simple wave through the DAC pin using HAL and STM32CubeIDE to configure the project. What I've checked that works: - Clock source- Trigger source- Output pin configuration- Built-in triangle and noise wave generation. I t...
HTD by Senior III
  • 4141 Views
  • 5 replies
  • 4 kudos
skills: How to read DBUMCU correct without debugging
I am useing ADC with STM32H743ZIT6 device.when i debugging,i find that the device can't read DBGMCU vale correct,although I read the 0x5C001000 address directly, i was so confused. Fortunately, I found the following skill.So Step 1 : Download you fir...
yqiu.11 by Associate
  • 739 Views
  • 0 replies
