STM32 MCUs Products
Is LWIP available for STM32H5XX
I just updated my STM32IDE to support the STM32H5 series parts and I noticed in my project that LWIP is no longer a middleware option. Is it not supported on this family?
mvonahnen by Associate III
  • 12379 Views
  • 17 replies
  • 3 kudos
Microcontroller Selection
Hello,I am in the process of selecting a microcontroller for my application and would like some guidance on which microcontroller would be best suited for my project. My project has the following known specifications/interfaces:- x3 UART ports up to ...
A_Matt19 by Associate
  • 1350 Views
ADC DMA TIM - U5XX Family
Good afternoon,  I have a question regarding the best strategy to follow on how to measure multiple channels with the ADC (triggered with timer) and map them to the DMA. I have followed the project called ADC_DMA_Transfer that can be found in the Pro...
Marc3 by Associate III
  • 1185 Views
  • 1 replies
Resolved! STM32H733 data cache initialization issue
Hello,I am using a STM32H733VGT on a custom design board. On a fresh project in CubeMX, I tried to activate data cache but the autogenerated code crashes at  SCB_EnableDCache(); . (nothing has been activated on the CubeMX, just the external crystal a...
amirshn by Associate III
  • 4937 Views
  • 9 replies
  • 1 kudos
Resolved! TIMER - Overflow event - Must reset CNT?
Hi There,I have setup TIMER4 on STM32G484 device for overflow event and enabled interrupt for events. Everything works fine and as expected with correct fire time if I RESET the CNT register in the ISR. However, if I do not, it seems to do some level...
Skeeb by Associate II
  • 2255 Views
  • 5 replies
STM32f407 boot mode
Hi I am using STM32F407 DISCOVERY BOARD and I am able to make the board change to boot mode using a another controller.After boot mode change over I need to program the memory of STM32F407 DISCOVERY BOARD by UART communication.Here I am unable to get...
AKHIL6 by Associate II
  • 1308 Views
Resolved! How to debug a hard fault exception for STM32?
I am currently using stm32f407 with FreeRTOS as operating system in MDK IDE. Recently, When I added a new function ( The new function is ospf routing algorithm, and it is very complex and involves many files ) to my project, I began to encounter hard...
yanhc by Associate III
  • 13877 Views
  • 13 replies
