STM32 MCUs Products
stm32L562 error connection SWD
Hi! I have custom board with new mcu stm32l562ve. Board has out pins - SWDIO and SWCLK.I am try connect by st-link v3. But mcu not connected. Also, i tested with connect nRST ( setting "Under Reset" in st-link ). But this variant same as first. MCVU ...
dlpPavlo by Associate II
  • 2599 Views
  • 8 replies
  • 3 kudos
Resolved! STM32F407 VREF+ voltage not 3.3V
Hi, I have a custom board in which VREF+ is supposed to be 3.3V. But the actual VREF+ (pin32) is 2.xV, with drifts between power ups. VDDA (pin 33) is 3.3V.What's wrong with the circuit schematic? Can I just remove the resistor (R22) between VREF+ an...
fzl by Associate II
  • 2292 Views
  • 5 replies
  • 1 kudos
Resolved! Blackpill and LIS3DH - issue with Sleep Mode.
When I use sleep mode while debug it sleep mode Works. But when I try runing code without using debug method it dosnot go in Sleep mode. When I chack current.When using debug method stape by stape.  Without using stape by stape debug method.Hear is t...
WhatsApp Image 2024-03-08 at 15.59.59_4747fd50.jpg WhatsApp Image 2024-03-08 at 15.59.59_c9f9cb4e.jpg
Resolved! BlackPill RobotDyn how to program it ??
Hi, I'm trying to figure out how to program this MPU with the Arduino IDE.I tried to make the serial port appear but without any success.Unfortunately I have lost all reference to the purchase and it seems that RobotDyn no longer exists.I tried the f...
Suntchi by Associate III
  • 15761 Views
  • 25 replies
  • 1 kudos
Resolved! Black pill serial communication not working!
Hey guys!I'm trying to run the eaxmple found in this link: https://deepbluembedded.com/stm32-serial-port-uart-with-usb-ttl-converter-pc-interfacing/I'm able to read the data from MCU serially, but when I write, the GPIO is not getting toggled. I've c...
zeus by Associate II
  • 9374 Views
  • 22 replies
  • 1 kudos
