STM32 MCUs Products
Generation of PWM wave with DMA
Hello all,Good day!I am working on a project to drive WS2812B RGB leds using STM32F030R8.These leds needs precisely timed signals of 800KHz. I am using a timer in PWM generation mode with DMA.These leds require each bit of data to be 1.25us long.When...
Jtag failure in stm32l471
Stm workbench shows jtag failure -4 when trying to set two gpio pins to high. One connected to boost conveter(enable) and other to telit modem on off.Is there any other settings I have to do to fix this error.Chip: stm32l471reGpio: port b, pin 0 and ...
SMano by Associate II
  • 763 Views
  • 0 replies
MCU device ID confused!
Q1: ​[RM0008] 31.6.1 MCU device ID code, DBGMCU_IDCODE says,"0x1003 = Revision 1, 2, 3, X or Y". It looks idiot. Does it means you still don't know what your revision is even you have read the DBGMCU_IDCODE​Q2: I have a stm32f10zet6 which is revision...
Cannot switch to PLL1
Hello,I am trying to switch system clock on H743ZI to PPL1. Using following code, it hangs up on checking SWS flag - clock switch begins, but never ends.I have tried setting domain prescalers before or after clock switch. The same for flash latency.I...
Need help to program an STM32F051K8.
I have an STM32F051K8 that I burned out on a Lumenier tx5gs vtx. It still transmits video but I cannot change channels. I thought it would be fun to try and replace it. Fortunately the 3.3v, GND, SWDIO, and SDCLK pins are all broken out on the board....
GWilk by Associate II
  • 1895 Views
  • 4 replies
STMicro announces #PlaysForSure program
Now if we can just get them to perform some rudimentary QA on the software they release we'll be golden.https://www.youtube.com/watch?v=nu2VJBz0MBA&feature=youtu.bePlease get you own house in order before doing this kind of marketing.#PlaysForSure (y...
STM32F429 IAP not working
Hai, I am using stm32f429igt controller I am trying to use IAP and found one example with stm32f4 cube package. While trying the example the code is not getting uploaded when I tried to upload it still waiting for the file can anyone help me how to s...
AChan.15 by Associate II
  • 2338 Views
  • 3 replies
