STM32 MCUs Products
Can't get from STM32H743 (LQFP100) ADC good accuracy
Hello,In my project, I sample the ADCs ( ADC1 & ADC2 ) every 1 millisecond. My ADC configuration :VREF = 3VFADC == 8M Prescaler = divide by 83 channels for each ADCSample time - 64.6 cyclesIn order to test my ADC driver, I inject 1HZ sinus. to 1 of ...
moranf by Associate II
  • 1290 Views
  • 1 replies
Resolved! STM32F072C8T6TR VDDIO2 power
Hello,I have a board that use STM32F072C8T6TR reference. After severel weeks of normal use, the STM32 on some boards are not responding anymore. I tried to access the STM32 with STlink Probe, ore by using internal Bootlaoder, without success. After i...
HVan .3 by Associate
  • 2126 Views
  • 3 replies
Resolved! About I / O static characteristics of STM32F746
Hello,​All I / Os are CMOS and TTL compliant (no software configuration required).For example, as shown in the attached document, the VOH in Table 57 has a different Min value depending on whether it is a CMOS port(a side) or a TTL port(b side).When ...
Resolved! UG bit ???
abbreviations are extremely poorly described throughout the documentation. you have to turn on the fortune-teller mode to understand what is happening. in particular, the UG bit has not been "reliably" deciphered. all documentation is "raw" and made...
STM32g031 deep sleep
Hello all!I am trying to play with the deep sleep mode of the stm32g031f8p6.Now i am using this: To sleep:  SystemClock_Decrease();  HAL_PWREx_ControlVoltageScaling(PWR_REGULATOR_VOLTAGE_SCALE2);  HAL_PWREx_EnableLowPowerRunMode();To wake up: HAL_PW...
NFahi.1 by Associate II
  • 2116 Views
  • 3 replies
Resolved! STM32F407VET CAN BUS interrupt does not trigger
Hi, I am trying to communicate on CAN BUS, I have previously succeeded in doing so with STM32F103C8 and STM32F091RC, but I cant make it work on STM32F407VET It does not trigger its interrupt on message receive. What could be the difference on this MC...
JBond.1 by Senior
  • 6287 Views
  • 14 replies
Resolved! Regarding CAN Open implementation in STM32L431RBTx
As we are using CAN 2.0 A (11 bit ID STANDARD FORMAT) in STM32L431RBTx MCU & it is working fine. Now we want to go for the CAN open protocol. Is there any sample code or document available or any algorithm to initiate CAN open code development for ST...
