STM32 MCUs Products
STM32F373CCT6 2 Channels Single ended wired together for 16 bit ADC interleaved 50 KHz to 100 KHz , Can it be done with 2 Differential channels at same speed 50KHz to 100KHz or is it stuck at 16Khz max speed in differential mode
Device STM32F373CCT648 pin We currently using 2 single ended 16 bit SADC inputs one on SADC1 PE9 and one on SADC2 PB2.We interleave the two 50KHz single channels using a 10uS delay between them. This uses DMA SADC transfer an interleaves the signal t...
NRST Assertion after Power on in STM32 MCUs
We are using STM32G041F8P6 MCU. Should we assert NRST reset after power on of STM32 or should we hold hold reset signal of STM32 during power up (any Power on Reset circuitry required)?Please let us know
sagar_bn by Associate II
  • 1180 Views
  • 1 replies
Put All ST drivers in some sector.
Hi Team,Here is what I'm expecting (this is only to reduce application size during FOTA):To put all the ST drivers/ libs/ middlewares/ etc to some sector in flash (lets say "ST-BSP"). In application/booloader to utilize this ("ST-BSP") sector content...
Resolved! Difference between cubeIDE's buitin cubeMX and standalone cubeMX?
Hi,I'm new to the STM32 ecosystem. Before I installed anything I was reading about the tools (STM32cubeIDE, STM32cubeMX, STM32cubeH7, etc) and I read that there is a buit-in version of cubeMX in cubeIDE so I didn't install the standalone cubeMX. Cube...
Rodo by Senior
  • 5536 Views
Resolved! External crystal on STM32F303CCT6
Hello all, I don't know why but my MCU STM32F303CCT6 don't work with external crystal, below schematics:The used crystal is ABM3B-8.000MHZ-10-1-U-T with load capacitors 10pF. Later I find in STM Datasheet that I should use resistor on OSC32_OUT pin. ...
MSzła.1 by Associate III
  • 4219 Views
  • 6 replies
