STM32 MCUs Products
Bus fault when running ARM DSP functions
1. I am implementing a custom extended kalman filter function. The program on running hits HardFault handler on the 4th iteration (prediction function).2. Cortex-M4->CFSR = 0x8200 (BFARVALID=1)3. BFAR holds : 0xa5a5a5a5I am not able to understand whe...
nalostta by Associate
  • 2728 Views
  • 3 replies
  • 1 kudos
CAN FILTERS
Posted on November 11, 2015 at 17:50 Hi every one, especially Mr.Clive, today i have problem with CAN FILTERS i want to allow all IDS from 100 to 1FF in other words block all messages after 0x0200 here is my code, Please help me, Thanks in...
puneethj by Associate II
  • 16902 Views
  • 23 replies
Resolved! STM32L45 I3C support?
Hi, I am using the STM32L45 series in my HW and I wonder if it can support I3C protocol?If not, is there another compatible MCU you would recommend?Thanks, yy
yy by Associate
  • 2285 Views
  • 3 replies
  • 3 kudos
No device found on target
I can't seem to connect to my STM32F401RCT6. This is the schematic below and all the jumper wires are working. Can anyone spot the error?When i try to connect to it i get the message 'No device found on target'
[STM32H745XI-DISCO] Unable to debug CM4
Hi community,I'm trying to launch an ANN on this discovery board.I build and programm both CM without error.However I'm not able to debug CM4 and have this error :Starting server with the following options:    Persistent Mode      : Disabled    Loggi...
BKOSI.1 by Associate II
  • 5567 Views
  • 9 replies
