STM32H723: How to achieve the Coremark figure? The published figure is 2778 at 550MHz. My implementation of Coremark at 480Mhz is a mere 327 with GCC ver10.3.1 and the default MX configuration. Is there an article on how to get full speed?
DavidO
AScha.3
just guessed: set optimizer -O2 or -Ofast ;
in Cube set caches ON and speculation default : enabled ;
if still "slow" , move test program to ITCMRAM and run there.
which optimizer setting you tried ? and cache setting ?
AScha.3
DavidO
Setting the caches ON and speculation enabled, took to figure to 1352, -Os to -O2 to 1868 and taking the frequency to 550MHz to 2136. Running from ITCMRAM will not be a practical option. That is a good result. Many thanks for the help.
waclawek.jan
ST also probably uses a "better" compiler, most probably IAR.
