STM32 MCUs Products
Resolved! USB_HID_Barcode Scanner
hi, Can anyone please help me in USB-HID-Barcode Scanner connection with stm32f722ze.   Normally Barcode Scanner will behave like keyboard and how to decode the ASCII code using usbh_hid_key.c .  Request : if anyone can suggest me small  example of u...
MMARI.1 by Senior II
  • 1414 Views
  • 1 replies
  • 1 kudos
Issue with DMA working with Ethernet
Hi! I'm using a custom board with STM32H563 and recently, I've set up the Ethernet connection, but I'm encountering issues with GPDMA interrupts for controlling a PWM signal for one wire communication to control addressable LEDs. In my project, I'm u...
JonConesa by Associate III
  • 3165 Views
  • 3 replies
STM32F103: SD CARD, SDIO
Hello, I am using the STM3210E-EVLA board. I want to create files on an SD card. While consulting the documentation for the STM3210E, I noticed that the size of the SD card is 128 Mbytes, whereas I am using an 8-GbytesSD card. I have written a simple...
rania by Associate
  • 5752 Views
  • 3 replies
  • 2 kudos
24C16RP EEPROM INTERFACING WITH STM32G070CBT6
Hello all,I am trying to interface 24C16RP EEPROM with my MCU soldered on breakout board and  it seems like the EEPROM is behaving very weird when i am trying to write and read. first of all it starts to write from position 1 not from zero of an arra...
RChou.1 by Associate III
  • 10065 Views
  • 11 replies
  • 7 kudos
STM32U575I-EV DCMI OV5640, maximize resolution for JPEGs
For the onboard OV5640 camera module that comes with the STM32U575I-EV, I would like to know how to get several of the largest resolutions for my JPEGs. I noticed the 2592x1944 that the OV5640 datasheet lists, but I'm also interested in whether other...
STM32U575I-EV FileX writes seem slow
The example project I'm basing most of my code off of is from the STM32CubeU5 MCU package  v1.4.0 (Projects\STM32U575I-EV\Applications\FileX\Fx_uSD_File_Edit). I'm looking to eventually apply this code to my primary project that saves JPEGs from a ca...
Resolved! Poor ADC quality on some Nucelo boards
Hi everyone :)I need your help. I am currently writing my masther thesis and I need robust and not noisy ADC read. I am using Nucleo board in my project so I hope hardware should have no effect in my case. The problem is ADC quality. I've tested thre...
KubaPy by Associate II
  • 3474 Views
  • 5 replies
  • 3 kudos
STM32F469I-DISCO NEW LCD Driver Missing NT35510
About a month ago (April 2021) I purchased STM32F469I-Disco from mouser.de here in Germany, my first discovery board with display. Things went fishy from day 1, but only after more than 2 weeks of black screen I realized: my disco has a different scr...
ilyus by Senior II
  • 7041 Views
  • 8 replies
  • 2 kudos
