STM32 MCUs Products
Problems blinking blue LED
Posted on May 31, 2013 at 14:53Hi all! I'm a newbie and I have problems with my STM32L-Discovery. I'm trying to do the simplest possible program: make the blue LED in PB6 output blink. This is the code I've made: #include <stdio.h>                  ...
STM32F407VGT6 + Kamera (OV7670) + Ethernet Stream
Posted on May 31, 2013 at 10:03Hello, I currently have the problem of the camera (OV7670) via Ethernet (UDP) to stream. I currently use the demo software and a simple UDP connection (server) to build, now I want to send the camera data in JPEG form...
samet by Associate
  • 1126 Views
  • 1 replies
decibel - microphone - st32f4 discorvery board
Posted on May 27, 2013 at 16:50 I test the microphone[MP45DT02] of stm32f4 discorvery board.    I use 1.024Mhz Clock input microphone with i2s signal. Pmd fiter of  library is applied and get pcm data from pdm data. Is it corret pcm data that no sou...
sojaewoo by Associate II
  • 2711 Views
  • 6 replies
STM32L1 STOP MODE
Posted on May 30, 2013 at 16:21Hi,Stm32l1 consumes much current than I expected. In standby mode, I measure 6uA consumption for my board but when I put it in stop mode it consumes 480uA. It should be around 10uA.The configuration is; USART_ITConfig(...
hs / fs usb, discovery f4
Posted on May 30, 2013 at 12:28Hi, I believe that FS is USB1 and HS is USB2. I have FS running in my project but can't seem to get HS running.I can run this ST sample on the f4 discovery board: http://www.st.com/web/en/catalog/tools/PF257882I have t...
ian239955 by Associate II
  • 2857 Views
  • 7 replies
STM32F4Discovery Audio Problem
Posted on January 20, 2013 at 15:12Hi all, I use the STM32F4Discovery Audio playback and recording example. I sound 1KHz from speakers and record the audio. The wav file I get is filled with click sounds. Also if I modify the code and keep everythin...
igal by Associate II
  • 2591 Views
  • 6 replies
Saving a Float to BKP Register
Posted on May 28, 2013 at 12:58Hi, I'm fairly new to the world of microcontrollers. I'm using the STM32F103ZG on the MCBSTM32E development board and am saving user-defined inputs to the BKP registers. Most inputs are positvie, small integers. Howeve...
lisa2 by Associate II
  • 1748 Views
  • 4 replies
Announcement
We’re moving the ST Community to a new platform to give you a better and more reliable community experience.
