STM32 MCUs Products
Resolved! Float value implementation and debugging
Is there a proper way to implement a float value? When i try to declare a float variable and debug via the variables tab and or live expression (global variable) I keep getting incorrect values in some instances. I have included the float library and...
NoviceStm32_0-1734424900179.png NoviceStm32_1-1734424937178.png NoviceStm32_2-1734424981648.png
Issues with KSZ9893 and STM32F427 Integration
Hello everyone,I'm currently working on a project where I'm interfacing the KSZ9893 Ethernet switch with an STM32F427 microcontroller. The setup uses the RMII interface for data communication and I2C for management.Issues i am facing:1.unable to ping...
priyazcs by Associate II
  • 2597 Views
  • 4 replies
  • 1 kudos
How to use Hyperflash/Hyperbus with STM32H562
Hello,I am trying to use infineons S26KL128SDABHI020 HYPERFLASH memory with a STM32H562VI microcontroller.For now I am just trying to do a simple write and read manually to make sure that everything is working.I use the OCTOSPI module with Hyperbus-m...
J_Kirsch by Associate II
  • 3933 Views
  • 6 replies
  • 1 kudos
Resolved! JTAG signals on STM32L433 [RESOLVED]
Hello,for the project I am developing I am using a STM32L433.We have connected a motor encoder signals to PA15 and PB3, that are CH1 and CH2 for timer1 TIM2 configured in encoder mode.We used CubeMX to configure the HW, and that worked perfectly for ...
MauroF by Associate II
  • 2751 Views
  • 6 replies
  • 2 kudos
