STM32 MCUs Products
cubeMX bug:Import STM32F769 project into SW4STM32
Posted on June 03, 2016 at 23:29 When import an STM32CubeMX generated project under System Workbench for STM32 follow the instruction of http://www.openstmorg/Importing+a+STCubeMX+generated+project. Numerous errors shown: unknown ty...
miluo by Associate
  • 1078 Views
I2C send_data
Posted on June 06, 2016 at 09:28hi,I'm using stm32f103rct6 to communicate with OPT3001 sensors.I use I2C1 for the configurationto read data from 16bits register it's done but I have problem to send 16bits data.I used this function when I tried to re...
aymen by Associate II
  • 2115 Views
  • 4 replies
uart interrupt reception problem in stm32f103
Posted on June 03, 2016 at 06:46hi,i'm doing n interfacing a sensor with stm32f103 via uart with 4800bps odd parity nd 1 stop bit.the code is generated using cubemx 4.9.0 . in the main code i m trnsmitting  a string.The problem is that wen i connect...
abhi by Associate
  • 1787 Views
  • 3 replies
Unable to download STM32CubeF2
Posted on June 06, 2016 at 08:49https://my.st.com/content/my_st_com/en/products/embedded-software/mcus-embedded-software/stm32-embedded-software/stm32cube-embedded-software/stm32cubef2.htmlThere's no ''Get Software'' button available!!!
Virtual COM Port: UART over USB for STM32F072
Posted on June 04, 2016 at 00:28Dear all,I am trying to get UART (USART?) working over USB for a STM32F072C8 part. The idea is to get basic getc/putc working via the USB for a custom board that we have designed. I intend to make the device  look lik...
gaurav2 by Associate II
  • 2218 Views
  • 3 replies
usb fs driver for stm32f103c8t6
Posted on May 23, 2016 at 10:45hello,please provide me usb fs driver for stm32f103c8 . I am also unable to find startup file for the same.please help me. #peripherals-stm32f103c8t6 #peripherals-stm32f103c8t6
MX, USB and Host vs. Device support
Posted on July 09, 2015 at 17:18Hi folks,New to USB here. I know (more or less ;) ) what the difference between host and device are but not a lot more.When configuring USB via 'MX, I find that if I set USB_OTG_FS as Host_Only, the USB Host middlewar...
hbarta2 by Associate III
  • 2624 Views
Does STM32F042 have built-in USB DFU bootloader?
Posted on June 05, 2016 at 13:04I am trying to determine if the STM32F042G4 MCU has USB DFU support in the built-in bootloader in system memory. The reference manual (RM0091, DocID018940 Rev 8) seems to say it does _not_: ''USB DFU interface (STM32F...
knielsen by Associate II
  • 1255 Views
  • 1 replies
