[SOLVED] STMStudio doesn't work after update to windows 10
office
Posted on December 17, 2015 at 09:18
Before I update my windows 8.1 to 10, STMStudio worked. After update and installation java 64bit it doesn't start. I have tried reinstall STMStudio, uninstall and install java but it still doesn't work. Other java aplications like eclipse or CubeMX work fine.
Anyone know how to solve this problem?
#stm-studio #java
Posted on December 18, 2015 at 11:10
Hi michal.l,
Could you precise version of both STMStudio and Java?
-Shahrzad-
S C
Posted on December 18, 2015 at 11:46
the current version of STMStudio requires the java 32 bits version to be installed, and does not work with the 64 bits version. Note also that with java-1.8 the shortcuts for the STMStudio are badly computed by the installer; the path to javaw.exe should be manually modified afterwards in order to point to the real location on disk of javaw.exe.
Those issues will be fixed in a next version planned for Q1-2016.
office
Posted on December 21, 2015 at 16:03
Thanks a lot SC. I have changed path to javaw.exe and STMStudio works.
