STM32 MCUs Products
When to set TIM1 pwm channels - 3phase drive
Posted on November 13, 2017 at 20:52Hello,I have a  project where a 3phase DC BLDC motor is required to be spined.For now i have : - 3 hall sensors conected to CH1,2,3 of the TIMER2.                          - 6 complementary pwms via Timer1In the T...
Bogdan by Senior
  • 710 Views
  • 0 replies
problem with IAR debug(?)
Posted on November 13, 2017 at 17:09hi. when i am debuging my code in IAR , debug 's Arrow  go to Disassembly and i cant continue debug, beacuse i think the arrow stop at that line.and i want debugger do line by line in my code and never go to the D...
Duty cycle of PWM unstable
Posted on November 13, 2017 at 13:29I have a problem with PWM generation.I have my own PCB with the uC STM32F429IIH. I am trying to configure the PWM in TIM3 channel 1. My clock frecuency is 180 MHz and APB1 Timer Clock is 90 MHz.I use STM32CubeMX t...
''Safe'' version of HAL_GetTick()?
Posted on November 09, 2017 at 21:04Using the STM32F413 Nucleo-144 and STM32F091 Nucleo-64 evaluation boards. I am using a combination of HAL_GetTick() and a read of the countdown timer to generate higher resolution time stamps for events. Using the...
Incorrect STM32F4 svd files?
Posted on November 09, 2017 at 02:50So I downloaded en.stm32f4_svd which contains the System View Description (SVD) files for the complete range of F4'sLooking at the STM32F429.svd in particular even though I believe they are all incorrect we have t...
alfbaz by Associate II
  • 1871 Views
  • 4 replies
How to remind for unanswered questions?
Posted on November 13, 2017 at 14:47What is a good procedure to remind for unanswered questions?For example if google is searched for 'STM32 pseudodifferential mode', two unansered questions pop up at top, 43401 from september and 44783 from end of ...
