STM32 MCUs Products
VREFINT
Posted on May 16, 2018 at 21:40In STM32L152 do we have the option to choose the VDDA as VREFINT?My other question is in regard to the VDDA battery monitoring.  If VREFINT is fixed how can we measure the VDDA please?  Therefore VREFINT_DATA would in ...
mmsya by Associate II
  • 5722 Views
  • 4 replies
SPI peripheral: BSY bit stuck after transmission
Posted on May 20, 2018 at 21:28 On an STM32F103 nucleo board I occasionally find my program locked in a loop waiting for the SPI2's BSY bit to become cleared. I am, honestly, totally clueless what is happening here. I am hardly able to track d...
Resolved! STM32CubeMX Multi-Drive Support with FatFS
Posted on May 16, 2018 at 10:46Hello,I have STM32F7 discovery kit (Discovery kit with STM32F746NG MCU) . I have successfully tested microSDCard withKeil + STM32Cube able to Create/read/Write txt files.I have also through UM1721 'Developing Applicati...
''Select first the target'' error
Posted on May 19, 2018 at 09:50..\stm32f4 library\CMSIS\Device\ST\STM32F4xx\Include\stm32f4xx.h(122): error:  #35: #error directive: 'Please select first the target STM32F4xx device used in your application (in stm32f4xx.h file)'plezse give me the s...
GPIO timing issue in Timer ISR
Posted on May 18, 2018 at 12:11Hello ,I am toggling a gpio inside the timer ISR . the timer ISR triggers for every 1 sec. Actually i am not able to see perfect 1 sec of gpio toggling . it also differs at different AHB frequency . i have included 2 c...
RN by Senior
  • 2332 Views
  • 8 replies
Resolved! STM32 MIPI checksums
Posted on May 19, 2018 at 16:21So, I am using STM32F769xxx to run MIPI-DSI display. On the display's datasheet there are power on and off sequences. I am able to get display on and off (so commands are at least somewhat OK), but colors and data on l...
