STM32 MCUs Products
STM32G431 OPAMP in PGA mode: noisy output?
Hi all,​I'm using STM32G431, the opamp1 and opamp2 are set as follows:the generated codes: hopamp1.Instance = OPAMP1; hopamp1.Init.PowerMode = OPAMP_POWERMODE_NORMAL; hopamp1.Init.Mode = OPAMP_PGA_MODE; hopamp1.Init.NonInvertingInput = OPAMP_N...
Jhon by Associate II
  • 1692 Views
  • 1 replies
Problems when i try to program the chip
Hello, im facing a problem when i try to program the chip, im using the eclipse ide and a cheap stlink debugger, the most common error is this:adapter speed: 24000 kHzadapter_nsrst_delay: 100Info : clock speed 24000 kHzInfo : STLINK v2 JTAG v34 API ...
Resolved! Interfacing to STM32F767ZI temperature sensor
Hello to everyone. I am teaching an embedded system lab courses and this is our first year with a STM32F767ZI Nucleo board. We are at a point where we want to exploit the on-board temperature sensor to generate some input data. In our first experienc...
PB1 by Associate III
  • 5547 Views
  • 9 replies
Start multiple ADC's DMA
I have tried to get ADC results from 8 different chanels on 3 ADC's using DMA so that the fresh values are always avaliable to me on STM32F303I used Cube MX to configure the ADC's and DMA's. After initisalization I did:   HAL_ADC_Start_DMA(&hadc1, (u...
PJera.1 by Associate II
  • 1356 Views
  • 1 kudos
Resolved! Entering and exiting stand-by mode on interrupt
I'm a beginner in embedded systems. I'm creating a software where some leds are blinking in the main while loop. I would like to put the MCU into stand-by mode when connecting a certain pin. I want to return to normal execution when this pin is disco...
varo1111 by Associate II
  • 1518 Views
  • 1 replies
stm32 series rotary capacity sensor touch example
Hello, I am currently developing a medical devicestm32 device related rotary capacityCircuit diagram and example code related to touch sensorIs a mustNo matter how much I look for it, there is an example related to the Liner touch sensorAs there are ...
NHor by Associate
  • 853 Views
  • 1 replies
