STM32 MCUs Products
Support for Unicleo-GUI-STM32MCU
Dear TeamGone through the user manual,refer the below linkhttps://www.st.com/content/ccc/resource/technical/document/user_manual/group0/b9/d0/7c/c5/a8/55/4c/bc/DM00337036/files/DM00337036.pdf/jcr:content/translations/en.DM00337036.pdfAlso find the b...
SS_135 by Associate II
  • 1162 Views
  • 1 replies
STM32F103VCT6 i2c2 setting trouble...
HiI am trying to communicate using i2c1, i2c2 of STM32F103VCT6.The pins are set as shown below.​- i2c1: PB6 (SCL), PB7 (SDA)- i2c2: PB10 (SCL), PB11 (SDA)​i2c1 is communicating correctly, i2c2 is not communicating with i2c1.When sending data, the bus...
ssooki by Associate III
  • 1531 Views
  • 1 replies
  • 1 kudos
Collision Detection on RS485 on STM32F103CB
Hi​I'm doing a topic to detect the collision on RS485. Since I wish to stop transmitting when collision occurred, I need to know how's the bus look like, however while transmitting, the transmit enable pin pull high on SP485EEN, lead the receiving p...
Olly Kao by Associate III
  • 1070 Views
  • 0 replies
Trouble setting I2C device registers
I am using an STM32L476 to run an MMC5983MA magnetometer and a LIS2HH12 accelerometer, using I2C. The devices are initialised using the STM cube generated code, then the registers are set, and then checked. When I check the accelerometer registers, ...
CGrov.1 by Associate II
  • 1784 Views
  • 4 replies
