STM32 MCUs Products
How to configure OctoSPI in Quad mode with PSRAM for memory mapped write access? Getting Hard Fault (FORCED, IMPRECISSERR) when write is attempted.
Hi there, I trying to configure octospi on STM32H7A3 to work with LY68L6400 PSRAM via quadspi.I have followed AN505 and managed to init, write and read from the memory successfully in indirect mode.Now I am trying to map the PSRAM to memory. I can re...
Fero by Associate II
  • 3039 Views
  • 3 replies
  • 2 kudos
SPI data transmission
Using STM32f3xxx series & using SPI2.I wanted to transmit 32 bits data at atime, but in APIHAL_StatusTypeDef HAL_SPI_Transmit(SPI_HandleTypeDef *hspi, uint8_t *pData, uint16_t Size, uint32_t Timeout) pData is fo r uint8_t.how to transmit uint32?
Bs.1 by Associate II
  • 1456 Views
Can not able to transmit continuously
Hi,i am transmit data through can protocol in stm32f103 controller in the while loop and i am doing doing adc and display data on 16x2 lcd so i found that doing this my can transmit is transmitting only 4-5 times amd then stop so i want to ask what c...
ABhat.7 by Associate III
  • 622 Views
  • 0 replies
