STM32 MCUs Products
STM32H750VB page size for flash erase - is it 128K, and if so, are there ways to partially erase the flash for persistent data storage?
I have application that fits comfortably in 128K bytes and has some persistent storage (data tables that are occasionally written by the application journaling-style, and occasionally a need to erase some of the data to accommodate more Here is my qu...
wb0gaz by Senior
  • 2971 Views
  • 3 replies
STM32F427ZIT6 lead time and availability issues
I have a product line using an STM32F427ZIT6 MCU which has been in production for several years. Suddenly it seems to be unavailable. Both Mouser and Digikey have zero stock and cannot even quote a lead time. Our production will be halted very soon. ...
krubow by Associate II
  • 1760 Views
RNG clock error on NUCLEO-L4A6ZG
I am trying to use the RNG on the STM32L4A6ZG but every time I enable the RNG clock RNG_CR |= RNGEN the RNG_SR shows CEIS and CECS.The AHB bus is at 80MHz and RNG_CLK is at 48MHz. I've tested with configuring the RNG_CLK to come from either the HSI48...
JKo by Associate III
  • 1524 Views
  • 1 kudos
JG by Associate III
  • 1019 Views
  • 0 replies
MQTT "Connection Refused: Unacceptable Protocol Version"!
Hi, I'm trying to implement MQTT using LWIP and got such a mistake. MQTT_CONNECT RETURN -1. Publish Err: -11 According to this link https://www.vtscada.com/help/Content/D_Tags/D_MQTT_ErrMsg.htmI have "Connection Refused: Unacceptable Protocol Version...
DK.7 by Senior
  • 2272 Views
  • 0 replies
