STM32 MCUs Products
Resolved! github and embedded projects
I am started a new embedded project, first time with GitHub, my question is about folder and control version organization, there is some good book, or another reference on this topic?
dhs by Senior
  • 1486 Views
  • 1 replies
ulrta low power 4 channel pulse counter
HiI would like to design an ultra low power pulse counter based. The LPTIM is the best option. However, my application require's 4 channels. Is there anyway to achive this with the STM32?BRGilberto
GErma.1 by Associate III
  • 1658 Views
  • 3 replies
  • 1 kudos
Resolved! STM32G474 Internal VS External DAC operation
Can anyone explain a usage case or purpose for the 4 Internal and 3 External DACs?Can you operate all three external DACs simultaneously to provide 3 reference voltages?
RMas by Associate II
  • 3715 Views
  • 3 replies
STM32G030F6P6 GPIO PROTECTION
HiI would like to use some GPIO to read pulses from a gas meter. The will be exposed outside the product. So, I was planning to use a TVS plus resistor to protect tge device.Can someone give any info on this? I believe that it is recomended, but the ...
  • 3794 Views
  • 1 replies
PWM with DMA, 8 bit
I am using STM32F401CCU. I am trying to generate PWM, using DMA. WHen i select DMA data size as word (16bit) it is working. But when I am trying to do Byte (8 bit) it is not working. Is it because the CCRx register 16 bit wide? Is there any way I can...
SumanB by Associate
  • 1707 Views
  • 3 replies
Regarding AD7768-4 FMCZ
Sir i am receiving Data for 1channel(8bit header + 24 bit Data ) using 16bit SPI and DMA in circular mode . i am not using AD7768 DRDY pin. I am recieving 1 vaild data after some grab data's (eg:0x00000000 , 0x008325DB) again somewhere vaild data(eg:...
SA  V.1 by Senior
  • 893 Views
  • 0 replies
Resolved! stm32L031K6T6 doesn't work, but it works in stm32L011K setting
I'm starting project with custom board that is controlled in STM32L031K6T6 MCU.I set up that with cube ide and wrote simple Timer code.Unfortunately, It isn't work. Not only that, Nothing is happend(uart, Hal_Delay, GPIO...)But oddly enough, it is wo...
remoter by Associate III
  • 2970 Views
  • 5 replies
