STM32 MCUs Products
Resolved! STM32h755 USART3
Hi everyone, I'm a student who was assigned to make an ESP32 NodeMCU WiFi CP2102communicate with the magnificent STM32h755zqi board via usart, simply I wanted to start by writing a simplesentence on the terminal (I know how to use putty) to actually ...
Resolved! STM32U5G strange UART bootloader behavior
Hi all,I'm using an STM32U5G7VJT6Q on a custom design PCB. From the application, I jump to the USART (UART1) system bootloader. I then try to connect to the bootloader via STM32CubeProgrammerCLI. The jump to the bootloader appears to be correct and t...
Resolved! The STM32H562RI programming and boot mode
1. How does the STM32H562RI MCU burn firmware into the internal flash of the MCU? What Settings need to be made for hardware or software? Can it also be burned to an external flash? How is it operated?2. Can the STM32H562RI MCU be boot from an extern...
Yuri_L by Associate
  • 361 Views
  • 1 replies
HAL_Flash_Program triggers HardFault exception
Hello everyone,I'm facing a weird issue about Flash programming on a STM32g0b1 microcontroller on IAR Workbench for ARM. ContextI'm working on a bootloader project. I am able to lock, unlock, erase and program flash at the beginning of my program. Fo...
