Lowest pin count QFP STM32 LCD RGB FMC
Gen-Tune
Hi ST community,
I am looking for some help with selecting the lowest QFP pin count STM32 for my project.
The STM32 will connect to the following below:
  • 18/24bit RGB LCD
  • FMC
  • QSPI
  • maybe MIPI (Optional)
Any FMC part number suggestion?
Use the product selector in CubeMX to find the chip that meets your needs.
With FMC and MIPI, QSPI, LCD, don't expect a low pin count device. I would guess LQFP144 probably has all of those.
After you find a chip in the selector, you may want to verify in a CubeMX project that the chip actually has all the pins for your specific choices within those peripherals.
