STM32 MCUs Products
STM32H735-DK: SMPS vs LDO interesting observation
Heyho,I just made an interesting observation on the STM32H735 Discovery concerning the internal core power supply.I'm working on an ethernet bootloader for my custom board using an STM32H733, which has no internal SMPS, only the LDO.As I do not yet h...
LCE by Principal II
  • 1485 Views
  • 1 replies
  • 1 kudos
Resolved! CubeMX STM32L4 code generation question
Hi folks,I use MX to generate a code for STM32L4. I noticed, when I configure timer in one pulse mode, I cannot set OC CH1 in PWM mode with CubeMX. I could set it manually after code was generated, but it would be overwritten if I run MX one more tim...
Lex by Associate III
  • 1206 Views
  • 1 replies
  • 1 kudos
SPI - not recieving a response on MISO line
Hello everyone!I'm trying to communicate with a slave device (ICM-42688-P: https://invensense.tdk.com/wp-content/uploads/2020/04/ds-000347_icm-42688-p-datasheet.pdf), but I don't recieve anything on the MISO line. I'm using the nucleo-wb55rg for the ...
customized keyboard using stm32 f44 series controller
Hello everyone,as I am developing keyboard with extra keys adding to the existing key board. I am adding extra modifier keys to the key board to perform the task. kindly let me know will it work and give suggestion inputs. my customized keyboard cons...
SSRIN.2 by Associate III
  • 4023 Views
  • 7 replies
  • 4 kudos
Resolved! How to get the value of the program counter ?
Hello, Sometimes I have my stm32F7 going in hardfault_handler, so for my customers I have to display on a screen the last address where the software crashed, then I can analyse which problem occure the crash. So I want to get the value "pc" (program ...
PierreG-S by Associate II
  • 4094 Views
  • 2 kudos
Resolved! STM32u585 Memory Mapped Read/write on B-U585I-IOT02A
While using memory mapped mode for APS6408L using STM32u585 on B-U585I-IOT02A, how is the row boundary crossing handled?* If I want to write across multiple Rows in memory mapped mode, do I need to handle this manually or is it automatically handled ...
Bootloader v11 + changes
I've been using an STM32G474xx in a project for a few years now and have a function that jumps to the bootloader. It seems in a recent rev of the chip the bootloader has changed. I'm finding that I can no longer jump to the bootloader similar to how ...
PCarn.1 by Associate III
  • 1637 Views
