STM32 MCUs Products
Hint: DMA and cache coherency
Posted on February 19, 2016 at 00:36To share experience with all: STM32F7 has DMAs and caches (DCACHE here in mind). You can use a DMA for Peripheral-to-Memory or even Memory-to-Memory (I use as HW-based 'background' memcpy() ). But you should bear ...
debug mode with IAR, MCU = stm32f405
I am developing the board with STM32F405 using IAR IDE. the problem is debugging mode. When i use hardware debugging mode on my developing board,the debug mode cannot control the program flow...  i command go-one-statement..but go so..many time i thi...
leejuhan by Associate
  • 1745 Views
  • 3 replies
  • 2 kudos
Resolved! Simulate a quadrature encoder on STM32F446RE
Noob here.  Using HAL and as much generated code as possible.   Ive run into an issue on how to self learn,  I've identified what I believe is the solution but nowhere( that I can figure out) in the reference document does it point to this in what I ...
Swyftfeet by Associate II
  • 3811 Views
  • 6 replies
  • 5 kudos
