STM32 MCUs Products
ADC glitches
Posted on September 24, 2011 at 18:39I have 1kohm potentiometer connected on pin PC4. On the sam pin oscilloscope is connected . Everything is correctly grounded and supplyed. On the scope (attached picture) I see 100mV glitches with a frequency of ...
matej23 by Associate II
  • 2959 Views
  • 6 replies
Use of memset and memcpy
Posted on September 26, 2011 at 11:27Hello, I am using STM32-P103 to decode NMEA sentences with some codes that they were already written and making small changes in them and I have notice that the use of functions like memset and memcpy makes the s...
sara2 by Associate II
  • 10923 Views
  • 11 replies
STM32 RTC Counter value Reset
Posted on September 27, 2011 at 10:23Hi , Im newbie about STM32 . I try to build a calendar project using STM32 discovery board. I can read counter value from RS232 port every second. I dissaamble SB1 resistor from discovery board and 3V lithium bat...
veyselka by Associate II
  • 857 Views
  • 0 replies
STM32F207 and ADC3 Problem - SOLVED
Posted on September 26, 2011 at 15:21Solved: I found a dead op-amp and some dry joints. First ever dead op-amp! But I'm not too surprised by the dry joints on the quad resistor array in a 1206 sized package. All analogs now look good!Hi, I've just s...
carl2399 by Associate III
  • 823 Views
  • 0 replies
USB stick access using OTG_FS in STM32F205ZE
Posted on September 24, 2011 at 13:23I am using following pins for USB stick interface OTG_FS_DM(PA11),OTG_FS_DP(PA12),VBus(PA9)In STM32f205XX datasheet it is given that it does not have OTG FS facility.Is it possible to configure these pins for OTG...
k_hraj by Associate II
  • 719 Views
  • 0 replies
STM32F207IG w/ STM3220G eval bootloading issue
Posted on September 21, 2011 at 17:35Hello everyone. This is my first time posting here and I am having issues with the IAP found here at STM's website. I am using Rowley Crossworks and the IAP files do not support that. Instead I created my own pro...
stbbrad3 by Associate II
  • 3702 Views
  • 14 replies
Are Pull-ups needed for SDIO
Posted on September 23, 2011 at 03:30Hello, I noticed that the schematic for the STM3220G-EVAL which uses an STM32F207 has a 47K pull-up on each of the non-power pins associated with the micro-sd card. I am currently designing a very space constrain...
