STM32 MCUs Products
stm32f3xx SPI read failure
Posted on August 24, 2016 at 01:18GreetingsUsing the HAL function  HAL_SPI_TransmitReceive()  to read erased data (i.e. all FF's) data from an external serial NOR device  I get a block of 0's at either the start or the end of a 256 byte read. Using ...
Assert_param problem
Posted on August 23, 2016 at 21:23Hello all,I'm a begineer with the ARM Discovery kit (STM32F4) and I'm trying to compile a test program when I try to compile it, an error appears : no definition for ''assert_param''. What I can do ? where does the ...
glias37 by Associate
  • 885 Views
  • 1 replies
STM32F4 Hall sensor output interpretation
Posted on August 23, 2016 at 16:25Hello there, In STM32F4 I am interfacing with a hall sensor attached to a BLDC motor. I have successfully configured TIM4 as HALL/ XOR inputs timer. The problem is, I am having a bit of a problem with interpreting h...
_
Posted on August 23, 2016 at 15:17 Thankyou for the additional pointers, this has given me some things to check out. It might take some time to get through it all but I hope to be able to do so soon. I'll write up a more detailed reply once I've man...
Write to USB stick using FatFS with DMA
Posted on June 28, 2016 at 16:35Hi,I would like to write data to an USB stick using FatFS with a DMA stream. I haven't found anything on this topic yet. I have found some example using an SD card, but I cannot apply this examples to an USB stick. Is...
smrtkai by Senior
  • 2487 Views
  • 6 replies
Generate a clear on/off PWM problem
Posted on August 22, 2016 at 18:08 Hello I have the necessity to generate a PWM out of a pin that stays active for 50us and then goes 0 regularly. In the attachment you see what I want to achieve. As you can see between some PWM the pi...
gnu by Associate II
  • 2808 Views
  • 4 replies
STM32F4 Discovery Kit with External Microphone
Posted on August 22, 2016 at 23:40Hello,I would like to interface an external microphone with the STM32F4 Discovery Kit. I have the onboard microphone (MP45DT02) working great, but the positioning of the mic makes it a bit difficult for my applicati...
nishant2 by Associate
  • 967 Views
  • 0 replies
SCCB, STM32F429DISCO + OV9650
Posted on August 22, 2016 at 14:15Hi,My code is the same as this post:/public/STe2ecommunities/mcu/Lists/cortex_mx_stm32/Flat.aspx?RootFolder=https%3a//my.st.com/public/STe2ecommunities/mcu/Lists/cortex_mx_stm32/SCCB%20emulation%20by%20I2C%20communi...
