STM32 MCUs Products
how to use st-link to reset stm32 chip?
Posted on December 26, 2016 at 12:50I use st-link tool in ubuntu,I found that 'st-flash reset' or  after I st-flash a bin file to the stm32 chipthe led action will not actually reset,for example, after on power, the ledA will not turn on,after I pre...
ctc.ctc by Associate II
  • 908 Views
  • 1 replies
Alternative SDRAM
Posted on December 15, 2016 at 14:53Hi everyone, this is my first question.I use STM32F746  and I need to interface SDRAM and this MCU. Micron SDRAM was used at the STM32F7 discovery however, at my stution this is not possible. There is any alternat...
STM32 with Thermal Printer
Posted on December 24, 2016 at 11:43Hi, i need to drive Thermal Printer with Stm32. On the internet there is no example about thermal printer with stm32. I have a A3967 stepper motor driver and RT638 thermal printer. Below datasheets. If anybody did...
About I2C Bus
Posted on December 21, 2016 at 16:03Hi all,I'm new on ST device, i'm trying to test the I2C bus but I can't understand how it works.. I do not want to use the HAL library but manage directly the register, but the I2C Interface on ST produce the stat...
STM32F4 & STM32F7 Series
Posted on December 23, 2016 at 11:39Hi,  I am a beginner to STM32F4 & STM32F7 series. I need to select a board with the STM32F4 & STM32F7 series that suits the following requirements:1. Inbuilt Ethernet Interface should be available2. Source code fo...
STM32F767 FMC data over write?
Posted on June 23, 2016 at 00:33Hello,I am working with the Nucleo-144 but I seem to be having a data overwrite issue with the FMC. At first I was having a problem getting the LCD to show anything. I found I needed to insert a delay between each com...
