STM32 MCUs Products
stm32cubemx ADC Dual Mode
Posted on February 12, 2018 at 15:54Hello,at first thank you for your community forum which helps engineers a lot in there work.my question is where i can take a good detailed tutorial about complex topics in STM32cubemx.the problem is i am using cu...
STM32F103C8T6 PWM Generation
Posted on February 02, 2018 at 14:49Hello! I have a question: How to generate a PWM on STM32F103C8T6 in Keil uVision 5. I watched some tutorials but I couldn't make it work, I want to enable TIM1 on pin PA11 and PA12. PWM needs to run at 20kHz => pe...
For confusion on selecting Graphical LCD for STM32F746
Posted on February 09, 2018 at 09:42I would like to develop HMI hardware using STM32F746 with 480x272 Graphical LCd, But i have confusion on selection of Graphical LCD?Am i select Graphical LCD with graphic controller or without graphic controller? ...
Gas Gauge(STC3115) Initialization on a custom board
Posted on February 13, 2018 at 17:22I am trying to get STC3115 working on a custom board based on STM32L476VX MCU. The battery used for the custom board is RJD3555. After initializing the I2C interface, the gas gauge always fails to initialize. Any ...
Does STM32F103RC support UVC(USB video class)
Posted on February 07, 2018 at 08:32Hi, I want to do a confirm that does STM32F103RC support UVC(USB video class)? Because I don't find the UVC related driver in STM32Cube_FW_F1_V1.6.0\Middlewares\ST\STM32_USB_Device_Library. We want to use camera i...
STP16CPC26XTR Led driver support
Posted on February 13, 2018 at 12:36Hi , I want sample code for  STP16CPC26XTR with interface STM32F103. Then how to connect more one STP16CPC26XTR with STM32F103. Please help anyone. Thanks & regards,Murugan K#stp16cpc26xtr #stm32f103
