STM32 MCUs Products
Not able to out the LSI clock
Posted on March 12, 2018 at 10:08 Hi, I was trying to out the clocks through MCO pin of STM32F0. Got HSE, HSI, SYSCLK and PLLDiv2. But i am not able to out the LSI clock. Can you help me? The code i had used is as follows. Hi, I was ...
INDHU N by Associate
  • 670 Views
  • 0 replies
Nucleo32 Sleep
Posted on March 10, 2018 at 18:53Hello,I have the Nucleo L43KC MCU. Is there any way I can put it into sleep or standby or other power modes? I noticed it doesn't have a wakeup pin unfortunately after I bought itThanks
Uart recive
Posted on March 11, 2018 at 14:33helloi use stm32f107 and use to standard standard peripheral library but now i have use hal drive and i new on it.i want to build a transmitter receiver.i want when receive data in mcu  i get an interrupt .when i use...
Linking to osxMotionAR library
Posted on March 12, 2018 at 01:23I wish to add the osxMotionAR library to my own project but cannot get the library to link to my project. Using AC6 IDE. Copied the osxMotionAR package to the directory \Middlewares\ST per Design Tip DT0047. I looked...
STEVAL-ESC: IAR Project -> ARM GCC Project
Posted on March 11, 2018 at 23:08Hi Dave - did this code run on the STEVAL-ESC? I'm going through a similar process, though I tried to 'upgrade' the FOC F30X example projects to fit the STM32F303CB in the ESC ... it's compiling in GCC but I'm gettin...
Sergei L by Associate
  • 780 Views
  • 0 replies
