STM32 MCUs Products
STEVAL-ESC: IAR Project -> ARM GCC Project
Posted on March 11, 2018 at 23:08Hi Dave - did this code run on the STEVAL-ESC? I'm going through a similar process, though I tried to 'upgrade' the FOC F30X example projects to fit the STM32F303CB in the ESC ... it's compiling in GCC but I'm gettin...
Sergei L by Associate
  • 788 Views
  • 0 replies
STM32F3cube 1.1.0 current state of MISRA compliance
Posted on March 12, 2015 at 15:23 Hello ST team, I am currently evaluating the STM32F3cube library. The documentation states, that it complies with MISRA 2004, which made me consider using the library in the first place. After so...
ru by Associate
  • 5195 Views
  • 12 replies
Resolved! STM32L1 Discovery Kit 5MHz PWM Generation
Posted on March 06, 2018 at 17:49Hello,I have been using the STM32L1 Discovery Kit with the STM32L152RCT6 MCU. A project that I am working on requires me to output two PWM signals. One of these is a 100KHz square wave and the other is 5MHz square wa...
ST-LINK/V2-1 software
Posted on March 08, 2018 at 21:23I'm designing a PCB and am interested in adding the ST-LINK/V2-1 programming and debugging board to it. I found the schematics and example PCB design in the http://www.st.com/en/evaluation-tools/nucleo-f103rb.html pa...
steval 3dp001v1
Posted on March 11, 2018 at 18:18I purchased a STEVAL 3DP001V1 3D Printer Evaluation board.I have flashed the Marlin4ST binary files.From what I understand the Wi-FI module comes configured and this appears to be correct as '3dpserver' appears on my...
STM32F100RB wifi
Posted on March 11, 2018 at 14:51hi, can i use STM32F100RB to interface SPWF04SA via UART or SPI? i checked around no much example using these two together. any API or tutorial example i can use and follow?
newest EM-WIN
Posted on March 11, 2018 at 14:48Hi.Does anyone know if / when ST will release the newest EM-WIN (segger).Best regardsS. Panduro #emwin
spa23 by Associate III
  • 781 Views
  • 0 replies
NUCLEO-H743ZI board LD39050PU33R
Posted on March 10, 2018 at 21:40On the NUCLEO-H743ZI board the LD39050PU33R 3.3 volt LDO provides voltage but what is the Vd or Vdrop for the LD39050PU33R? I found I can add 3.7 volt (18650 battery) to JP3 pin 3  : I can't use VBAT as it is wired t...
KevinA by Senior
  • 1491 Views
  • 3 replies
