STM32 MCUs Products
SMBUS Communication Problem
I used STM32F051R8T6 Discovery Board. I need SmBUS Communication to use Bq78350 (Texas). I need smbus example. The examples on your websites are so complicated and not working good. Can you send me simple example ? I am designing a bms system with st...
SBAYD by Associate
  • 677 Views
  • 0 replies
DFU, OTG FS, Dfu-util and Bootloader
HelloI have a project that I must realize. I have to use the USB port FS of the STM32L475 card to be able to make the firmware updates by using the DFU.I successfully downloaded the firmware of the card with DfuSe Demo and then I tried to flash the M...
Hani by Associate II
  • 1056 Views
  • 0 replies
failed to use L3GD20 with STM32F3 discovery and keil
Posted on September 27, 2015 at 22:35Hi, I am trying to use stm32F3 discovery gyroscope with keil  MDK.I used the template project provided by st and added the gyroscope head and .c file to the project.Unfortunately, when i build it i get this error...
d4ng3r09 by Associate II
  • 1503 Views
  • 3 replies
USB MSC sometimes is detected by my PC and sometimes is not
So I'm trying to implement the USB mass storage with an SD card connected to the STM32L4.I am using the STM32l476RG Nucleo board and have added the HSE clock source to the board.I have successfully implemented 1-bit SDIO with the FATFs middle-ware wh...
BGavr.3 by Associate II
  • 2828 Views
AWS Trust Service (ATS certification)
Hi, I'm using a Discovery IoT Board B-L475E-IOT01 with application FW STM32CubeExpansion_Cloud_AWS_V1.2.0. I test the application with my think registered on AWS on september, that use the following endpoint ULR: a8yx4uphexpln.iot.eu-west-2.amazonaws...
ABarb.5 by Associate II
  • 806 Views
  • 0 replies
Is EEPROM Emulation possible with STM32F030F4P6 MCU ?
I wish to read/write data from FLASH Memory (i.e., execute EEPROM Emulation since internal EEPROM is not available).I referred to firmware example code for STM32F030R8, the User_Flash that user can read and write starts from PAGE_16 to PAGE_63 i.e, 1...
PNach by Associate
  • 1156 Views
