STM32 MCUs Products
Resolved! where can I find the register addresses for STM32L476RG?
Hi,I have a STM32L476RG board and I try to execute the following program, obtained from this web http://www.microdigitaled.com/ARM/STM_ARM/Code/Ver1/Chapter02/Program2-1.txt which is for a different Nucleo 64 board (STM32F446RE)/* p2_5.c Toggle Green...
MFaun.1 by Associate II
  • 7634 Views
  • 14 replies
STM32F469 CAN Rx Issues
Hello, I am attempting to transmit a simple CAN message between two STM32F469I discovery boards. I am using the official STM32F4 github as reference found here: https://github.com/STMicroelectronics/STM32CubeF4/tree/master/Projects/STM324x9I_EVAL/Exa...
Header files required for programming STM32F446 MCU in C
I am new to ARM processor and I need to know what are the header files required in main.c for programming the above MCU in C by just accessing its registers (and manipulating bits) as explained in RM0390 (REFERENCE MANUAL for STM32F446xx) ?NOTE: I am...
STehA.1 by Associate II
  • 6493 Views
  • 3 replies
Resolved! Issues in changing baudrate of USART1 on the fly
Posted on July 02, 2018 at 11:00Hello,I am using an STM32F042 controller. I have to send a wake-up pattern followed immediately by 5 bytes (@10400 baud) from my device. Wakeup pattern: 25msec LOW followed by 25msec HIGH5 byte sequence: 0xC1, 0x11, 0...
How timers in STM32F7 start workig?
While preparing slides for students about timers in STM32F7 microcontrollers, I came across several inaccuracies in the description of their work presented in the STM32F7 reference manual RM0410 rev 4. The following sentence can be found in the menti...
MirKoz by Associate III
  • 3295 Views
  • 5 replies
  • 1 kudos
TIMx_ARR relations to the preload and shadow register?
In RM0008 Technical Reference Chapter 15, TIMx_ARR was introduced in counting mode. Meanwhile, two other registers: preloaded and shadow register, were also mentioned. However, in the TIMx register Map, Preloaded and shadow registers were not mention...
KSun.11 by Associate II
  • 2899 Views
  • 3 replies
  • 1 kudos
