STM32 MCUs Products
Errors while trying to port a C++ library
I'm trying to import an Arduino C++ library into an STM32F4 project. I set the project to be a C++ one while I was creating it. I've also made the necessary code changes needed for the STM32. However, while compiling I'm getting the following errors....
How to communicate with and configure the STMWBC-MC?
I am looking to incorporate STMWBC-MC in a charging dock and I am unable to locate information on programmability of this chip.I will be using a host STM32 MCU which will be interfaced with the Qi transmitter. I would like to know more about the diff...
GRang.1 by Associate II
  • 738 Views
  • 0 replies
Resolved! Having problem to understand DMA
I am trying to learn DMA properly by reading from STM32F407 reference manual . But I am confused at some points. First is about FIFO mode:- Lets say I am receiving data from UART over DMA and I am using DMA FIFO mode with threshold 1/2(that is 8 byte...
SSone.1 by Associate III
  • 2545 Views
  • 3 replies
Soil Moisture sensor i2c
Hi, I need help ...I would like to be able to read the soil moisture sensor https://tinovi.com/wp-content/uploads/2019/03/PM-WCS-3-I2C.pdf of which the arduino library exists (https://github.com/tinovi/i2cArduino) using a stm32 microcontroller. There...
Oscillation in ADC measurement of DC value
Hi everyone. I am trying to measure the voltage of each battery connected in series to other. I am measuring voltages over voltage divider to reduce voltage below Vdda. When I measure the voltage of node with multi-meter there is no oscillation seen....
  • 2149 Views
  • 4 replies
Migrate from STM32F207 to STM32F429
Hi all, I am a senior developper but not so experimented with STM32 ecosystem.I have a new board equiped with a STM32F429, which is based on an old board equiped with a STM32F207.So I would like to re-use (and adapt) the firmware of the old board rat...
APICH.1 by Associate II
  • 2097 Views
  • 5 replies
