STM32 MCUs Products
Sometimes LPTIM2 does not start when using one shot mode. I see this happened 4 years ago to another user and their question went unanswered. So I'll try. (STM32L4R5ZIT6)
// Code to start the one shot timer void set_delta_alarm(Long t) { LL_LPTIM_Enable(LPTIM2); while (0 == LL_LPTIM_IsEnabled(LPTIM2)) ; LL_LPTIM_SetAutoReload(LPTIM2, t); // * TE_SECOND / ONE_SECOND); LL_LPTIM_ClearFLAG_ARRM(LPTIM2); LL_LPTIM_Star...
RChap.1 by Associate III
  • 3090 Views
  • 0 replies
Resolved! Can a low power timer (LPTIM) drive an RGB LED in STOP mode?
MCU: STM32L4R9ZGJ6Hardware: Custom battery powered boardLED: ARGB1313HSDesired LED functionality: Blink, on/off, fade in/out ("Breathing")Hello,I am familiar with a regular timer and how they can drive a RGB LED using multiple channels (CCx registers...
DerekR by Senior
  • 2993 Views
  • 5 replies
Launching option bytes bricks the MCU
Hi,I am trying to set the write protection on my STM32G071 uC. I found the explanation here on how to do it in code. However once HAL_FLASH_OB_Launch is executed, the debugger loses connection and the uC is bricked. I tried to get a connection again ...
Specific ARR value interrupt
Hi,I am usinfg STM32F0 and TIM1(16 bit) , ARR value has to be 0xFFFF and I want to generete interrupt for specific ARR value etc(when ARR is 32500). My project is very complicated. What is the best way to do this ?
hdemi.1 by Associate III
  • 1076 Views
  • 1 replies
Resolved! SWV doesn't display the right information
Hi!! To test how the SWV data trace timeline graph works, I have a simple application where I increment by 1 a variable called count. Very basic. In debug mode, I see count increasing correctly in the live expressions window. while(1){ count++; HAL_D...
mdiro by Associate III
  • 1409 Views
  • 1 replies
