How to wakeup from STOP mode by using RTC and EXTI?
dkuma.1
I'm using an STM32L051R8 in STOP mode with a 32.768KHz external crystal (LSE) that drives the RTC.
I have set the RTC to generate periodic wakeup interrupts every X seconds, It's working.
But I also want to wakeup using the external interrupt, whenever external interrupt generated by the LIS2DE12.
So, please help me how to do that.......
KnarfB
EXTI interrupt can wakeup the MCU. Configure a pin as EXIT and it should work. For detaiols see 6.3.6 Exiting low-power mode in the Ref.Man. and/or watch avideo (other MCU): https://youtu.be/UtQhc4XV8k4
hth
KnarfB
