STM32 MCUs Products
Problems with UART transfer using DMA on STM32L471RGT6
Hi , I am using DMA/serial port transfer with RTS /CTS handshaking to transfer between 490 and 506 bytes from variable dma_buffer. The byte stream is terminated with \r\n\0 . the code is below : while (transmit_complete_flag !=1 ){;} // wait here un...
rwils.1 by Associate III
  • 1504 Views
  • 1 replies
RTC of smt32F103C8T6 is not incrementing time seconds while VBAT is connected to a 3v coin cell on VDD cut-off, but it only retains the last value but not increasing.
RTC code is not working properly while VBAT is connected to a 3v coin cell, it only retains time from the last value but not incrementing as the time increases please let us know what's wrong with the codeI'm following this below linkhttps://www.micr...
ashutamar by Associate II
  • 1588 Views
  • 1 replies
Setting MCO2 output on STM32G0
Hi,I'm trying to get a clock output at 460.9 Khz on PB2 by setting the MCO2.The PB2 pin is declared as follow:static void MX_GPIO_Init(void){ GPIO_InitTypeDef GPIO_InitStruct = {0}; /* GPIO Ports Clock Enable */ __HAL_RCC_GPIOB_CLK_ENABLE(); /*Config...
MAmem.1 by Associate III
  • 1932 Views
STM32- Timer not working as expected,
void External_Clock_Config(){ TIM_ICInitTypeDef TIM_ICInitStructure; TIM_OCInitTypeDef TIM_OCInitStructure; NVIC_InitTypeDef NVIC_InitStructure; GPIO_InitTypeDef GPIO_InitStructure; RCC_APB2PeriphClockCmd(RCC_APB2Periph_TIM1, ENABLE); /...
jsaun by Associate II
  • 1434 Views
  • 1 replies
Resolved! STM32F051 to get code coverage report
Hi ,We have SEGGER J-TRACEpro for CORTEX-M processors . https://shop-us.segger.com/product/j-trace-pro-cortex-m-8-18-00/ We want to take the Code Coverage report . We are using Ozone IDE and loading the .OUT file to the OZONE IDE .There are 2 cables ...
ck.1 by Associate III
  • 15887 Views
  • 3 replies
  • 2 kudos
stm32f0 SPI does not receive data
When data size equal to 3 rx buffer last element is true only others are not. I expected all of them is true data. Why it is working like that ? I examine the result on debug modestatic void Init_SPI2(void) { SPI_InitTypeDef SPI_InitStructure;   ...
hdemi.1 by Associate III
  • 2121 Views
  • 4 replies
