STM32 MCUs Products
First time programming a stm 32 - key matrix
Hello all!I'm in the process of designing my first full custom sim racing steering wheel. I have designed and ordered a pcb with a stm32f103cbt6 mcu. The pcb works good (so far) and i have it connected to my pc via a swd clone st link debugger. I am ...
JLoes.1 by Associate
  • 3275 Views
Does the STM32CubeIDE have a truncate function?
I am working with a Nucleo-L476RG board, and I am writing a program that generates HMAC-SHA-256 values. I want to truncate the output of the generated HMAC value to only output n amount of bits. For example, if my generated HMAC value is 80 bits, I w...
stmmm by Associate II
  • 1323 Views
  • 1 replies
Resolved! STM32F7 Memory map in AN4839
We have a question about the memory map in section 3.1 of AN4839. The note states that "by default the MPU is disabled and that in this case the memory map is defined as the default address map".Immediately under this statement is a table with a memo...
Nevyn by Associate II
  • 2348 Views
STM32L4 ADC oversampling - What is the total sampling time ?
I using STM32L4 ADC in my project to sample analog acceleration data. The ADC conversion is triggered by 10kHz timer by which i was able to achieve 10kHz sampling rate using DMA. Now, i wanted to implement oversampling by a factor of 2. Now what is m...
KK.4 by Associate II
  • 3448 Views
  • 3 replies
Resolved! Is there any way to know when a STM32H7 SPI master has completely finished sending data, in endless-transaction mode?
When transmitting in endless-transaction mode with the STM32H7 SPI periph. (that is, setting TSIZE = 0), how can I know when the master has finished transmitting all data? Not only that its Tx FIFO is empty (which could be done with TXP) but also tha...
DGast.1 by Associate III
  • 1536 Views
  • 1 replies
Announcement
We’re moving the ST Community to a new platform to give you a better and more reliable community experience.
