STM32 MCUs Products
Blanco stm32h757 programming first time.
Hey,I have an STM32H757 that I’m trying to program for the first time.When I try to program it using STM32CubeIDE or CubeProgrammer, I lose the ST-Link connection after programming one of the cores.Changing the programming order doesn’t solve the iss...
MVops by Associate
  • 454 Views
  • 3 replies
  • 1 kudos
custom surveillance drone with STM32N657X0H3Q
Project Name: custom surveillance droneCase Description:Hi STMicroelectronics Support Team,My name is Shuvadeep Mazumder, and I am the Founder & CEO of Model of Engineering (https://modelofengineering.com). I am currently leading the development of a...
LTDC support
Hi i am working with LTDC with STM32F429ZI Discovery -1 board with onboard LCD. I really want to drive a external LCD RGB display without An ic controller by utilising the Internal LTDC hardware inside the MCU . Can you please give some support on th...
b1aze by Associate III
  • 932 Views
  • 6 replies
  • 3 kudos
Resolved! STM32H747BGT6 MIPI-DSI VDD12DSI
Hi, I have a question about supplying power to DSI interface on STM32H747BGT6 (208 LGFP package).RM0399 says, "The DSI interface is supplied from a dedicated VDD12DSI supply that can be provided eitherby the integrated DSI regulator or by an external...
el659 by Associate III
  • 673 Views
  • 4 replies
  • 1 kudos
Resolved! STM32H747BGT6 SMPS and USB supply pins
Hi, Im planning on using STM32H747BGT6 in LDO mode only and no USB interfaces will be used. What should I do with SMPS pins (VSSSMPS, VLXSMPS, VDDSMPS, VFBSMPS) and USB supply pins (VDD50_USB and VDD33_USB)? The datasheet nor the application note don...
  • 290 Views
  • 1 replies
  • 2 kudos
STM32 Unable to get Core ID
Hi All,I'm new to using the STM32 and honestly had great grief trying to connect to the chip.I'm using STlink V3 and designed my own PCB.Trying to flash a F/W to the PCB. I ordered the PCB from JLCPCB.I keep getting unable to get core ID as a message...
