STM32 MCUs Products
Flash wait states meaning
Hi i have a generic doubt about falsh wait states:Say we configured the PLL to run system core clock at 160 M Hz, with flash wait states as 5.Then is cpu is equvilent to 32 MHZ core performance? (assuming 1 clk/ 1 inst, no ART's)Could some one help m...
RKall.1 by Associate II
  • 3352 Views
STM32F469 - Execute code from QSPI Externa NOR Flash
I want to interface N25Q.. External NOR flash with STM32F469. Where I want to load and execute the code from N25Q External flash memory using QSPI memory mapped mode.Is this solution is Possible?If yes, from where I can get support?
jigish by Associate
  • 7279 Views
  • 12 replies
  • 2 kudos
STM32F407VE sampling signal with ADC.
Hello everyone, i'm sampling an analog signal, using an single ADC triggered by a timer, and to observed the reconstructed signal i use a DAC connected to an oscilloscope.I have the next configurations:ADC parameter settings:Clock prescler: PCLK2 div...
yuarth07 by Associate II
  • 3879 Views
  • 5 replies
stm32f429vet6:raw tcp:lwipsetting
kindly suggest lwip setting for stm32cube ide for below for receiving 14000 bytes regularly in tcp raw as clientTcp_Wnd,Tcp_Mss,heap memory size,Pbuf_Pool_BUFSIZEmy values are-:Tcp_Wnd=32000Tcp_Mss,=1436heap memory size,=45000Pbuf_Pool_BUFSIZE=2048i ...
MGOEL.1 by Associate II
  • 1353 Views
  • 1 replies
USB_FS CDC VCP
Hello everyone,I am trying to transfer data to LabVIEW using USB_FS (CDC, VCP). The reason, I shifted to USB_FS (12Mbits/sec) from UART was lower data transfer speed (115200 bps). However, I have one concern regarding USB_FS as CDC. I checked the VCP...
