STM32 MCUs Products
HRTIM output is not observed as mentioned in datasheet
Hello Team,I would like to mention an error I’m facing while testing the HRTIM module in STM32G474RE Evaluation Board. Please find the error details below.Evaluation Board Used: STM32G474REIssue details:In the STM32datasheet: stm32g474ce_details.pdf ...
FEngi.1 by Associate II
  • 983 Views
  • 1 replies
DR register outputs incorrect numbers STM32F407VG
Hey STMcommunity, I am trying to implement a Modbus protocol, however the DR register of the USART i am using does not output the correct numbers.    I am sending the following message to the MCU "11 03 00 04 00 04 07 58" (hex numbers) but get the fo...
Jordi_ by Associate
  • 1009 Views
  • 1 replies
Resolved! Strange USB Behaviors
Greetings, Sorry if I am posting in the wrong place.  Maybe someone can point to the correct forum for me.Problem: USB HID 04 Joystick intermittently sends incorrect 12-bit analog data.Micro: STM32F103R8T6Details: A 1/2 Hz signal applied to analog in...
Loren by Associate III
  • 6671 Views
  • 13 replies
  • 1 kudos
STM32H743 Vrefint value is always read as 0xFFFF
Hello to everyone,I have encountered a problem trying to work with ADC data on STM32H743 chip. When I read VREFINT value (19th ADC input channel) I always see 0xFFFF. Data on other channels look slightly more adequate (at least they are changed depen...
OIrin.1 by Associate II
  • 3614 Views
  • 6 replies
Please use B&W text in documentation
In some newer STM32 documents, such as ES0418, text is rendered in various tints of blue. This results in decreased readability and problems when printing.Can ST please constrain fancy color schemes to marketing material, and use conservative black-o...
Resolved! Advice, please, how to view the function call tree and the contents of the MCU stack using STM32Cubeide. After the program crashes in debug the program loops in Hard_Fault_Handler () and it is not clear what cause such event.
What ability to view the contents of the call stack in CubeIDE is present?, i.e. what functions were called before the crash, preferably in the form of a tree
olezhandr by Associate III
  • 13287 Views
  • 9 replies
  • 7 kudos
Resolved! STM32L5 System View Description
The system view description files for H5 and U5 are on the website, but it is not for L5 (https://www.st.com/en/microcontrollers-microprocessors/stm32l5-series.html#cad-resources). Where can I find it ?
mete by Senior II
  • 2258 Views
  • 4 replies
