STM32 MCUs Products
ST32F217 with STE100P. How to configure PHY address?
Posted on April 04, 2012 at 07:04STE100P how to set PHY address?Hello. Im trying to using an STE100P PHY ethernet chip (with ST32F217 MCU). In the datasheet for STE100P i see an description for bits 7~3 PAD4:0 in PR20- XMC, XCVR Mode control registe...
andrey23 by Associate II
  • 2315 Views
  • 4 replies
Ethernet PHY DP83848CVV
Posted on April 04, 2012 at 13:55Hello, I want to use DP83848CVV as Ethenet PHY with STM32F207ZET6 in RMII mode. In Schematics (STM3220G_EVAL),there is some resistor of 51 Ohm in between of  signals (RMII_REF_CLK,RMII_TX_EN,RMII_TX_D0,RMII_TX_D1,RMI...
migrating from Atollic to IAR
Posted on April 05, 2012 at 07:39Hello, reasently i changed ide to iar and i getting strange problems: i have working code developed in atollic and tested on my discovery boards, but then i use same code on IAR, it just doesn't work. Like touchscre...
linas2 by Associate II
  • 1686 Views
  • 3 replies
STM32F207
Posted on April 04, 2012 at 12:16Hello, I would like to download a C compiler for STM32F207. Where I could find it? I was searching through the forum, but without success. #stm32f207 #c/c++-compiler
dove457 by Associate
  • 1465 Views
RTC calibration
Posted on March 29, 2012 at 07:42Hi all,I wanted to know is there any software workaround to compensate for negative ppm values.I am using STM32F100V8 controller. According to the rtc digital calibration manual(attached) you can only subtract the cy...
Boring problems with ST LINK on STM32LVDISCOVER
Posted on April 04, 2012 at 17:17Hi folks,I have big problems with connecting to ST LINK integrated on ST discovery kit. I already install all utilities, driver updates (V2) and  test all tips and trick posted in forum, but the result is same...''Ca...
Register or Standard Peripheral Library
Posted on March 31, 2012 at 17:58Hello, I am new to this forum. Is there anyone who does not use Standard Peripheral Library for programin STM32F4 ? I'm don't like SPL and and programmed using registers for set the uC. I greet
we by Associate II
  • 1796 Views
  • 7 replies
Backlight Driver STLD41 producing disturbance on TFT
Posted on April 04, 2012 at 14:08Hello I am using STLD41 as backlight driver for 5.7''controllerless TFT. Whenever STLD41 gets on it produces lines on TFT & display gets disturbed.If i give backlight power seperately from power supply Display works ...
APB1|2 Peripheral Reset Registers
Posted on April 04, 2012 at 15:44The reference manuals don't really define what these registers do (at least RM0041).   I assume that toggling one of these bits resets the corresponding peripheral to its initial state.  That seems to be confirmed by...
