STM32 MCUs Products
APB1|2 Peripheral Reset Registers
Posted on April 04, 2012 at 15:44The reference manuals don't really define what these registers do (at least RM0041).   I assume that toggling one of these bits resets the corresponding peripheral to its initial state.  That seems to be confirmed by...
Getting Started, MCU plays dead ?
Posted on March 05, 2012 at 03:33Hello, I am trying to get started with STM32 microcontrollers. I have a STM32F103RBT6 on a development board and I am using the gcc toolchain (target arm-elf, flags -s -Os -mthumb -mcpu=cortex-m3). The sample code I...
Getting started (progamming STM32 in C++)
Posted on March 19, 2012 at 10:07Hi, I've started a job where we use STM32 microcontrollers, programmed in C++ developed in Eclipse. I'm an electronics engineer with a solid understanding of microcontrollers (however my experience is with PIC and AD...
colm by Associate
  • 2010 Views
  • 3 replies
ethernet (UDP and TFTP)
Posted on March 30, 2012 at 16:19 Hi everybody, I want to make an Ethernet connection between the stm32f4 discovery board and my computer. I use a DP83848 Ethernet Board ( http://www.wvshare.com/product/DP83848-Ethernet-Board...
New F0-Discovery board with 'F051 Cortex-M0 report
Posted on April 01, 2012 at 20:03Grrrrr!!  I just wrote a long post about the new F0-Discovery board, and the forum software threw it away. Rather than re-write a thoughtful post, I'll do what the crappy forum software encourages me to do and write ...
donald2 by Associate II
  • 1665 Views
  • 3 replies
pin VBUSON stm32-h107
Posted on April 02, 2012 at 22:40Hello to all, i have a question regarding stm32-h107 : in order to use feature usb on the go, should i connect pin USB_VBUSON to Vdd? Best Regards, Dion
dion by Associate II
  • 1293 Views
Cannot for the life of me get TIM2 to trigger ADC1
Posted on April 03, 2012 at 08:00 Hi all, Bit at my wits end here. I have been trying for quite some time to get ADC1 to trigger on TIM2 CC2. To start with, I tried to use TIM3 TRGO with about the same amount of luck (ie none). Everything...
jeremyh by Associate II
  • 695 Views
  • 0 replies
STM32F100RC -- GPIO in standby mode
Posted on March 31, 2012 at 12:02What is the state of GPIO pins when microcontroller is in standby mode?  Each pin remembers it's own state: input, output, analog, pull-up, logic level on it?  Which document (datasheet, etc) and where specifies this...
sysop by Associate II
  • 2105 Views
  • 4 replies
