STM32 MCUs Products
STM32F205 and USB virtual com port problem
Posted on August 13, 2013 at 14:36 Hi all,  I'm using STM32F205VGT,STM32_USB-Host-Device_Lib_V2.1.0 and virtual com port driver ''VCP_V1.3.1_Setup_x64.exe''. The PC works with Windows 7/64bits. When I start USB device the initialization of USB start...
donev_g by Associate II
  • 867 Views
  • 1 replies
User button
Posted on August 19, 2013 at 12:18hello i'm trying to make the user button working with a simple led program here is the code and please tell me what's the problem (it worked just when i keep pushing user button then make a reset): ****************...
STM32F3 - AN4296 - ISR FROM CCM RAM USING IAR
Posted on August 20, 2013 at 02:38Hi,I would like to receive a working project the demonstrate how to execute an interrupt handler from CCM RAM using EWARM. I tried the procedure from AN4296 section 2.2. The project compiles,  but when the ISR is tr...
Asantos by Senior
  • 996 Views
  • 1 replies
Calculate delay
Posted on August 14, 2013 at 21:24hello how can i calculate a delay of 1 second if i have this parameters: SYSCLK(Hz)                             | 168000000   *-----------------------------------------------------------------------------   *       ...
Hard - to catch - fault
Posted on June 04, 2013 at 09:50Hello, I have a kind of strange issue. When I really stress my system (it handles serial packets, get the right data, and send it via serial, I send thousands of messages without waiting for reply), in an unpredictabl...
root by Associate II
  • 6395 Views
  • 24 replies
STM32W108 discontinuation statement
Posted on July 23, 2013 at 12:06Hi, The Zigbee PRO support has been dropped by ST a while back... Since then I've been trying hard to find some document from ST stating the product discontinuation so we can present that to our customer... I've tried...
nelson by Associate II
  • 2969 Views
  • 9 replies
GDBserver flash programming problem
Posted on January 27, 2012 at 13:47I use Eclipse-IDE and CodeSourcery G++ Lite to create programs for STM32F4xx. As debugger I use CodeSourcery gdb and gdb-server from Atollic TrueSTUDIO Lite package. If I debug program located in flash on Sector 0 ...
glory_man by Associate II
  • 26243 Views
  • 1 replies
Help me fix my code.ADC with STM32F303VC
Posted on August 19, 2013 at 07:20I want read ADC of STM32F303VC then display status  on three LED (If ADC>1000 LED red bright,ADC<500 LED green bright and extant LED ogrange bright) programmed code below,but i don't find error.Thanks everyone!#incl...
bee by Associate II
  • 716 Views
  • 0 replies
